Guide: how to generate playlists using Playlist Generator Pro on schedule.
Here's a guide how to do it.
First of all, you should create a preset in the Playlist Generator Pro and save it. It's called "Day" in the example.
Then, in RadioBOSS, create a new scheduler event, click "Wizard" button. Choose "Perform an action", click "Next".
In the next window, choose the preset. Presets created in the Playlist Generator Pro come with [pro] prefix. Click "Next" - that's it.
You don't have to use the Wizard each time. The command to generate playlist with Playlist Generator Pro has this format:
generate [pro] preset_name
Substitute preset_name with your preset name.
If you get "error 259" when this event starts, try increasing the "Maximum time to generate playlist by schedule" setting - it's located in the RadioBOSS Settings window, General section.
