PiGenerator Pro : Optimize generation commands and generating 24 playlists in 13 minutes
Altec
Hi Dmitry,
Just to let you know that I discovered why the Generation of My Daily playlists was so long... I discovered that many months ago but I had no solutions to show and to purpose but now I have !
I'm generating every evening by a .BAT (and formerly by the Sheduler into radioboss) one day program with 24 playlists, During my day I have differents time slots with different musical ambiences following the all day, these time slots can be 3 Hours 2 hours or 6 or 4 hours, it depends on the day of the week.
I'm charging M3u playlist hour by hour with Sheduler in my Broadcasting Studio and in The Backup one, that's why I'm working with 24 playlists.
In the Pi Generator i used to generate this kind of command :
Exemple for a Day between 00H and 12H :
That thing gives this command :
"C:\Program Files (x86)\RadioBOSS\PlaylistGeneratorPro.exe" "-preset=ALTEC-NIGHT|ALTEC-NIGHT|ALTEC-NIGHT|ALTEC-NIGHT|ALTEC-NIGHT|ALTEC-NIGHT|ALTEC-MORN|ALTEC-MORN|ALTEC-MORN|ALTEC-MORN|ALTEC-MORN|ALTEC-MORN|ALTEC-LUNCH|ALTEC-LUNCH" "-out=C:\PL\playlist_00.m3u8|playlist_01.m3u8|playlist_02.m3u8|playlist_03.m3u8|playlist_04.m3u8|playlist_05.m3u8|playlist_06.m3u8|playlist_07.m3u8|playlist_08.m3u8|playlist_09.m3u8|playlist_10.m3u8|playlist_11.m3u8|playlist_12.m3u8|playlist_13.m3u8" -n=1 -s=0
Problem with that for each preset the Pi Generator restart from 0 and reload all the database wich cause extremely long generation for a day and the 24 playlists.
So ! I had the idea of a script using this functionnality to avoid the Pi generator reloading every hour generated :
"C:\Program Files (x86)\RadioBOSS\PlaylistGeneratorPro.exe" "-preset=ALTEC-NIGHT" "-out=C:\PL\playlist_%nn.m3u8" -n=6 -s=0
Base command is that so I used a .bat. to show you what I'm doing here is an example I reproduced for a complete day :
We could do it more even more quickly If PIGenerator could load all categories needed for all the preset un 1st step and after that generate each presets.
Kind Regards
Altec
