Stop commands
Hi Dmitry
I'm really pleased to see that it is possible to schedule stop commands in Playlist Generator, so that a user doesn't have to programme hundreds of stop commands manually.
Two things to ask you this time.
(1) The problem is that a generated stop command does not appear to work. RB just keeps playing through without stopping on the generated stop.
(2) When the playlist stops at a stop command, I have to hit the keyboard twice to start again. Also, when it does start, it plays the previous track, and not the next one.
I trust these are just small issues and easy to fix. Thanks for your help.
James
