Stream Archive Question
gg2064
Tested in RadioBoss 6.2.0.0 and 6.2.0.1.
When Stream Archive is started via the toolbar icon or from the tools menu the substitute values for file naming (e.g. %y%m%d) work as expected.
However, when the streamarchive command is used in an event ("streamarchive on R:\_Recordings\%y%m%d"), the substitute values do not work and the resulting file name is:
%y%m%d.mp3.
Is this the way it is intended to work and if so would it be possible to implement the substitute values to work as they do for the toolbar icon and tools menu methods?
Thank you
