The PC from which you stream has to have a static IP address accessible from Internet (or at least on the computer where you will be receiving the stream). Then you configure the built-in web server (use the Wizard when adding an encoder) and to receive the stream use the link http://IP:port where IP is your IP address and port is the port where you configured the server.
