Track information do not follows playback
tomimatko
When playing the Track information does not refresh automatically. Only when I click the track in the playlist... And yes there's workaround - enable Selection follows playback. But in 5.9 it works without that...
There are two options you can use, eithse "Selection follows playback" or "Track information follows playback" to have the playing track info loaded to the track information panel.
Doesn't seem to reproduce here. Please try the latest RadioBOSS 6.0.3 version, is the problem still there?
Yes, version 6.0.3.1. On two different PCs (Win 7) it's same. When "Track information follows playback" is checked and "Selection follows playback" is unchecked the info window for playing track is empty.
The first track from a event is OK, but for all next tracks when there play the Info window is blank.
In 5.9 with same settings everything was fine.
