We have been using Track Tool to shorten up tracks at the end of an hour.
Two issues:
Two issues:
- the setting sticks and if the track is used in a playlist later it will fade out/end according to the previously set time. Which you won't notice until the track plays. Is there a better way?
- It seems that if you set a fade out and an endpoint there is a brief jump to full volume before the next track starts.
