Type of ad track
NestorC
In the properties window of the ad in ADS Schedelur, there is a value "Type" that is: type of the ad track, also the help says: "The type is used for showing warnings in case two or more tracks of the same type are placed side-by-side (or example, two pizza commercials in a row"
Is there a way to edit that table and add or remove values?
You can input anything to the Type field. The list is formed based on the values you enter.
Yes, you can input anything there, but the list is NOT updated!... when you want to input a new track and view the list, no new inputs are there!
I found that those values are saved in the file: adscheduler.ini, but that list is not updated... Is there a tool inside RB to update it?
