• English
  • Deutsch
  • Español
  • Русский
RadioBOSS box
Author Topic: RADIOBOSS.FM stream hosting [beta]  (Read 98231 times)
  • Administrator
    • http://www.djsoft.net
Re: RADIOBOSS.FM stream hosting [beta]
« Reply #15 on: November 23, 2012, 04:59:48 AM »
The problem located... For some weird reason, in database, the limit for e-mail address was 32 characters, while your e-mail is longer. It's fixed now.
Christian
« Reply #16 on: November 23, 2012, 05:38:59 AM »
Ok, the encoder is now connected but the stream URL for listening from the interface does not work. I get a 404 error in winamp. The URL is : http://s1.radioboss.fm:9084/stream/1/
Christian
  • Administrator
« Reply #17 on: November 23, 2012, 05:51:04 AM »
That's because you connected as Shoutcast v1 source, while hosting works in ShoutCast v2 mode only.
Copy-paste the settings from the Account page to RadioBOSS. In particular, you have to specify the stream ID in Server, eg.
s1.radioboss.fm:9084,1
Christian
« Reply #18 on: November 23, 2012, 06:42:26 AM »
It's when I setup as "Public" server. When "Private" I can listen.
The issue is that I cannot login to the administration side to register to Shoutcast to create the Authhash!
  • Administrator
« Reply #19 on: November 23, 2012, 08:13:20 AM »
OK, thanks. This will be fixed in the future, and admin password will be published in the Account page.
Christian
« Reply #20 on: November 23, 2012, 08:23:09 AM »
Not sure on how the final service will be setup but here is my view. As a broadcaster it is important that the stream is available over http on port 80.
Many listeners listen at work in there office as it's a convenient way to access music. Companies firewall rules usually block major radio and musical services but they cannot block all "small" webradios. To go through most companies firewall you have to use http on port 80 has this mostly remains open even for streaming.
Christian
http://clubbingstation.com
  • Administrator
« Reply #21 on: November 23, 2012, 10:00:38 AM »
Giving port 80 to everyone requires unique IP for every user... But the point you've made is interesting, I'll take a note.
Christian
« Reply #22 on: November 23, 2012, 10:54:15 AM »
That is why I a curently using IceCast so all my streams are from same IP and on port 80.
timgreb
« Reply #23 on: December 26, 2012, 10:23:35 AM »
New service launched: http://www.radioboss.fm
It's a SHOUTcast v2 stream hosting for radio. Currently it's free!
The only hosting plan available: 50 listeners @ 128kbps, MP3 or AAC+
Do you have the hosting avalible yet?
  • Administrator
« Reply #24 on: December 26, 2012, 12:47:53 PM »
Yes, you can register at http://www.radioboss.fm and stream for free.
timgreb
« Reply #25 on: December 26, 2012, 01:43:05 PM »
I am using that stream, testing it to see how stable it is
Plus is there a way to make it stream Media player and not Real player?
Thanks Tim
  • Administrator
« Reply #26 on: December 26, 2012, 03:28:32 PM »
Probably we'll add Windows Media Services hosting in the future, but currently it's not available. Sorry...
timgreb
« Reply #27 on: December 26, 2012, 11:21:08 PM »
Media player script I made this and it shows the title and artist from radioboss in media player
http://s1.radioboss.fm:9132/listen.m3u?sid=1
It works great for me, not sure what numberss you have to change but I'm guessing 9132
Hope this works for you, it does for me
Casey
« Reply #28 on: December 28, 2012, 08:06:26 PM »
FYI>>  Working fine in my corner of the World..   :)
Casey
timgreb
« Reply #29 on: January 23, 2013, 11:57:29 AM »
Are the streamers down?
s1.radioboss.fm:9132,1
It don't work even on your site
Please let me know
Thanks Tim
