• English
  • Deutsch
  • Español
  • Русский
RadioBOSS box
Author Topic: RADIOBOSS.FM stream hosting [beta]  (Read 99836 times)
  • Administrator
    • http://www.djsoft.net
Re: RADIOBOSS.FM stream hosting [beta]
« Reply #60 on: May 01, 2013, 03:14:23 AM »
I think you should contact streamlicensing support about this... How do they validate a stream?
hymnsinger
« Reply #61 on: May 01, 2013, 03:11:09 PM »
Streamlicensing says they need the stream server username and password. Is that the issue that has come up in other threads about beta versions?
  • Administrator
« Reply #62 on: May 02, 2013, 02:41:24 AM »
Yes, I think so. This will be fixed soon and you'll see this information on the Account page.
hymnsinger
« Reply #63 on: May 15, 2013, 03:49:49 PM »
Dmitry, where is the accounts page? Any more info on the beta stream? Thanks.
  • Administrator
« Reply #64 on: May 16, 2013, 02:28:42 AM »
Account page is the page which appears after you login... The issue with admin login is not fixed yet.
flopyplus
« Reply #65 on: May 16, 2013, 01:29:14 PM »
Hello, is the server down? I´m trying connect but is imposible. Thanks!
  • Administrator
« Reply #66 on: May 16, 2013, 01:44:55 PM »
There was a technical issue - please login into your account at radioboss.fm and start a server. Sorry for the inconvenience.
flopyplus
« Reply #67 on: May 17, 2013, 05:15:51 AM »
Ok, thanks. Now its working.
hymnsinger
« Reply #68 on: May 31, 2013, 11:58:45 AM »
Any update about stream server username and password so that I can get the stream validated?
Thanks.
  • Administrator
« Reply #69 on: June 06, 2013, 10:52:17 AM »
hymnsinger, please check your e-mail.
danu
  • Guest
« Reply #70 on: August 01, 2013, 04:32:45 AM »
my stream the encoder is now connected but the stream URL for listening from the interface does not work. I get a 404 error in winamp. The URL is : http://s1.radioboss.fm:9618/stream/1/ [nofollow]
I also can not get into the admin login, do not know the password and username .. please its support thx
  • Administrator
« Reply #71 on: August 01, 2013, 04:51:38 AM »
Try restarting the server from the control panel -  it should fix the 404 error.
Admin access is not possible yet, we'll release service update soon which will fix this.
hymnsinger
« Reply #72 on: August 07, 2013, 01:02:43 PM »
My radioboss.fm stream is not connecting as of late last night. I tried to login and the page won't open either. Any thing going on with the streaming?
johngrant
« Reply #73 on: August 07, 2013, 01:09:56 PM »
Mine went down at about 5:00 AM PDT.
hymnsinger
« Reply #74 on: August 07, 2013, 03:08:20 PM »
Hi johngrant. I saw your thread after I posted this one.   :o Mine went down last night about 10 pm Eastern time USA.
The login for radiobossstream won't open either.
