• English
  • Deutsch
  • Español
  • Русский
RadioBOSS box
Author Topic: USB Mixer noise?  (Read 4583 times)
USB Mixer noise?
« on: November 13, 2016, 11:35:34 AM »
I ahve a USB Mixer with noise, Like static noise on my mic. I am wondering how can i get rid of it any ideas? I have a MXL R150 mic XLR should not be a problem what do I do?
DavenLC
    • LiquidNoise
Re: USB Mixer noise?
« Reply #1 on: December 10, 2016, 08:59:48 AM »
ground it (?)
  • Experienced user
« Reply #2 on: December 10, 2016, 12:39:32 PM »
Sources of noise:
 - cooler fan from laptop;
 - conditioner air;
 - too much gain from mixer;
 - volume fader too high;
 - compressor too high.
Try reduce gain and volume.
If there is noise with gain and volume off then try DavenLC's solution.
Sometimes there are driver conflicts.
« Last Edit: December 10, 2016, 11:00:00 PM by pety »
« Reply #3 on: December 20, 2016, 11:18:14 PM »
Well its got a Noise Isolator on it so yea its grounded.
DavenLC
    • LiquidNoise
« Reply #4 on: December 24, 2016, 08:12:28 AM »
Its possible your PC Fan noise is bleeding over.   You can try using a different Mixer or disconnecting PC fans one at a time to see where the noise is being generated.
« Reply #5 on: December 25, 2016, 05:19:59 AM »
I am gona get a Focusrite 2i2MK2 and try that .
« Reply #6 on: December 30, 2016, 03:00:32 PM »
I got a Focusrite 2i2 2nd Gen and its amazing so fare as for hardware wise.
DavenLC
    • LiquidNoise
« Reply #7 on: December 30, 2016, 07:25:04 PM »
awesome!
« Reply #8 on: December 30, 2016, 08:09:33 PM »
Yea but software wise junk, Like windows 10 and stuff and drivers junk it crashes my pc some times.
DavenLC
    • LiquidNoise
« Reply #9 on: January 02, 2017, 04:51:10 PM »
Do you have the mixer plugged into a USB3.0 port?
« Reply #10 on: January 04, 2017, 11:13:07 AM »
Yes I just bought a USB 3.0 card lol, With 4/5 USB 3.0 ports lol.
