• English
  • Deutsch
  • Español
  • Русский
RadioBOSS box
Author Topic: volume keep going up and down..  (Read 7657 times)
  • Administrator
    • http://www.djsoft.net
Re: volume keep going up and down..
« Reply #15 on: February 23, 2017, 04:03:32 AM »
one of my streaming clients facing that problem from a long time ago...
what i suggest to them is to restart the software.
Please tell them to contact our tech support about this problem. We've never received such requests from registered customers - below I'll provide more details for the volume problem in my reply to radiobellissima.
so, if i'm here, you have another bug in your software [in my demo version now]
Thank you for this bugreport, if the bug is confirmed, it will be fixed in the next update.
  • Administrator
« Reply #16 on: February 23, 2017, 04:07:54 AM »
I confirm I also another reason here I uninstalled the demo. After three days it becomes impossible to use the volume goes up and down
The demo version of RadioBOSS only works for 5 hours then it has to be restarted. Your so called "demo" version works for 3 days.
Software piracy was never a good way to acquire software.
  • Administrator
« Reply #17 on: February 23, 2017, 04:12:45 AM »
In addition to the statistics that go down after a few hours of operation which does not happen with any other statistical software they are always on.
There are no problems with statistics retrieval in RadioBOSS. You just need to use the version we provide on our web site, not any other version. Please see my above post. The lack of 5 hour limit in demo, the volume problem and the statistic problem have the same roots.
radiobellissima
« Reply #18 on: February 23, 2017, 10:17:23 AM »
I had already uninstalled because of all these problems. At this re discharge point the demo from this site and try again. I told him to register the software and restarted on its own but can not remember if every 5 hours. Anyway to fix the audio had to close it and I do not restart by itself. ???
  • Administrator
« Reply #19 on: February 23, 2017, 11:10:06 AM »
You should only use the original RadioBOSS that is downloaded from our web site: http://www.djsoft.net
All the problems you experienced exist only in the cracked version. Cracked version doesn't work correctly, and from our research, most (if not all) cracked RadioBOSS versions are bundled with viruses that corrupt the system, steal passwords etc.
  • Experienced user
« Reply #20 on: February 24, 2017, 02:39:32 AM »
That's right ! :)
radium98
« Reply #21 on: February 26, 2017, 02:07:30 AM »
AGREE.
