Alert window -> Delete All
Sometimes when I build a playlist I accidentally click on [Delete all...] instead [Calculate start time...].
Is it possible to add an alert window message, before delete all content of playlist?
Thanks a lot!
If you accidentally deleted the playlist, you can undo the action using the Edit->Undo command.
I used this option, but it is not accurate all the time.
If playlist is not playing and there's no playback queue, it should work fine. I'll see what we can do with this option, maybe we'll add it to "Advanced settings" to allow you enable the confirmation.
