Roaming/DJsoft.net/Radiobos_ ......
vanilla
New files are constantly being generated in this specific path, eventually consuming a significant amount of disk space. This leads to storage exhaustion and system instability. I attempted to delete some files manually, but I encountered an error message after the deletions on the log screen.
  • How can I automatically delete older files?
  • Is it possible to change the storage path to a different drive?
  • What exactly do these folders contain, and are all these files necessary?
ps, i have more than one installations of RB in the same PC
This is a folder where RadioBOSS keeps its settings, all settings for each RadioBOSS instance are kept in RadioBOSS_nnnn folder. If you have multiple folders, looks like you have installed RadioBOSS multiple times to different folders and/or your installation got corrupted.
At least one of the RadioBOSS_nnnn folder is necessary, the one that's used for your main installation.
Please tell what RadioBOSS versio do you use. You can find out the number that's used by your installation: right-click the RadioBOSS shortcut, select "Open file location", in the folder open the uid.ini file, you will see the number there. This is the settings folder that's used, other folders can be removed (if you only have one installation).
thanks, So, is there really no way to prevent these folders from constantly expanding in size?
Aside from essential settings, what exactly is being stored on a daily basis that causes such significant growth, and where is it located?
Specifically:
  • Is there a way for me to track down these files?
  • Can I stop this automatic accumulation?
  • Can I safely delete specific elements that are not essential for the system to function?
They do not expand much, the log files are rotated, therefore their max size is limited, the only folder that will grow in size is Reports folder because it stores reports for each day (you can delete the old report files if you don't need them).
If you disable report creation, some functions (e.g. Report Viewer) will stop working.
How large is the folder? You can enable "Compression" (a Windows feature, right-click a folder and select Properties) to compress the reports.
I would advice against this as you may break something.
