• English
  • Deutsch
  • Español
  • Русский
RadioBOSS box
Author Topic: Presenter Assist (Manual) Mode  (Read 1492 times)
Chris Deacon
« on: December 04, 2019, 08:40:02 AM »
Is there a way of manually running ads when the scheduler is in manual mode?  I want to be able to allow scheduled ads to appear on the screen at a particular time so that presenters can manually play them to air, similar to the music tracks in a playlist, with the music tracks also pausing after each track.
ie: Can the ads be enqued so as to wait for a current (manually started) track to finish, and then the presenter start the ad or ad block manually?  What settings can achieve this?
ArtSound FM
Canberra
  • Administrator
    • http://www.djsoft.net
Re: Presenter Assist (Manual) Mode
« Reply #1 on: December 04, 2019, 10:20:08 AM »
If adverts are inserted to the playlist, they will also stop between after each track if you have the "Stop after this track" playlsit option enabled. The "Manual" option in the playlist makes scheduled events countdown but they will not launch.
Chris Deacon
« Reply #2 on: December 05, 2019, 12:59:59 AM »
Thanks Dmitry, I will try that...and thank you for creating the "next XXXX" fade command!
ArtSound FM
Canberra
