• English
  • Deutsch
  • Español
  • Русский
RadioBOSS box
Author Topic: Help With Playlist Generator  (Read 366 times)
DjDominic
« on: January 07, 2020, 01:21:13 PM »
I can't get the Playlist generator to work in a scheduled event. Everything appears to be set up correctly and the scheduled event starts but nothing happens. I have the setting set to add the playlist at the end of the current playlist. I did notice this error today in the Generator log "Unable to save log file to C:\Users\Pinole Radio\AppData\Roaming\djsoft.net\RadioBOSS_1284383840\Log\playlistgenerator.log".
  • Administrator
    • http://www.djsoft.net
Re: Help With Playlist Generator
« Reply #1 on: January 08, 2020, 07:59:44 AM »
It looks like there's no write access to the RadioBOSS settings folder, and therefore it can't sabve the log, and, possibly, generate playlists. Please try rebooting the PC and also make sure no other software locks the folder or in some other way prevents RadioBOSS from writing there.
DjDominic
« Reply #2 on: January 08, 2020, 11:21:19 PM »
The folder is not locked. I have tried everything I can think of to get it to work. Like I said the scheduler starts the but nothing happens. No playlist ids being generated.
  • Administrator
« Reply #3 on: January 09, 2020, 04:12:31 AM »
What happens if you create playlist manually from within Playlist Generator, does it work?
The error message you have
Quote (selected)
means that RadioBOSS can't write to the settings folder, and until this is fixed, it will not work properly.
DjDominic
« Reply #4 on: January 09, 2020, 12:57:40 PM »
If I use Playlist Generator manually it works.
DjDominic
« Reply #5 on: January 09, 2020, 08:46:03 PM »
I think I know why I thought it wasn't working. I didn't give it enough time to generate the playlist. Normally it takes about 10 minutes generate a 24 hour playlist due to the large number of music files we have. So I am testing right now to see if in 10 minutes it appends a playlist.
DjDominic
« Reply #6 on: January 09, 2020, 09:55:31 PM »
The scheduler timed out before generator was finished generation the playlist. I changed the settings in scheduler to give it more time. Testing it right now to see what happens.
DjDominic
« Reply #7 on: January 09, 2020, 10:55:50 PM »
I got it to work. The key is if you have a lot of files, change the scheduler time out.
  • Administrator
« Reply #8 on: January 10, 2020, 07:56:35 AM »
The default timeout is 10 minutes, it appers that it was almost enough for you. Still it's odd as in your original post there was no error message about it timing out.
DjDominic
« Reply #9 on: January 10, 2020, 06:22:43 PM »
[/quote]
There probably was  an error message but I most likely didn't see it.
