• English
  • Deutsch
  • Español
  • Русский
RadioBOSS box
Author Topic: Uploading listeners to broadcast  (Read 1694 times)
0 Members and 2 Guests are viewing this topic.
radio maran
« on: February 09, 2020, 07:59:21 AM »
Can listeners be broadcast for broadcast via RADIOBOSS.
If so, I'd love to know how to do it?
  • Administrator
    • http://www.djsoft.net
Re: Uploading listeners to broadcast
« Reply #1 on: February 10, 2020, 05:09:56 AM »
Can you please provide more information, I'm not sure I understood the request.
radio maran
« Reply #2 on: February 10, 2020, 07:33:32 AM »
I want to make programs that listeners ask questions, and the pros answer. Is there a way in RADIOBOSS to raise the listeners so they can ask the questions?
Hope I explained myself well.
  • Administrator
« Reply #3 on: February 10, 2020, 09:53:20 AM »
RadioBOSS is a playout software, it does not support listener calls by itself, you probably need some other software to handle calls and then tie it to RadioBOSS to stream audio from calls.
radio maran
« Reply #4 on: February 10, 2020, 04:33:25 PM »
Thanks.
In the way I find such software, how do I link it to RADIOBOSS?
  • Administrator
« Reply #5 on: February 11, 2020, 08:02:13 AM »
You can use virtual sound cards to route calls to RadioBOSS. Each setup is different based on your needs, you can find some examples here (for Skype, but it's more or less the same for other software): https://www.djsoft.net/smf/index.php/board,11.0.html
radio maran
« Reply #6 on: February 11, 2020, 08:13:05 AM »
Thanks.
If I am now broadcasting through a cloud computer, and have a virtual sound card, is there a special virtual card required to bring listeners?
  • Administrator
« Reply #7 on: February 11, 2020, 10:21:34 AM »
I can't tell help you with this, as this does not refer directly to RadioBOSS, I'm sorry.
