muzycznemiasto
I’d like to share my free studio tool I’ve created for editorial, technics room and studio.
TOOL display timing, programme broadcast details, and key technical information.
The app shows the current program along with the time remaining. It's a great studio supplement for RadioBoss.
- works as standalone webpage (no install needed)
- show actual radio programme with countdown rings
- lists the next two scheduled broadcasts
- features include a visual alert if there is silence lasting longer than 15 seconds
- show accual weather (change location in settings)
- until the top of the hour—highlighting the display three minutes prior and making the section flash one minute before
- you can customize server address (indicator check stream condition)
- you can modify broadcast schedule via settings
- ring colors via the settings menu (the gear icon at the bottom)
- prelisten stream, with mute and volume functionality
-audio analyze section (goniometer, loudness radar, spectrum analyzer, VU Meter with RMS, PEAK, CREST meter, mono deviation, coreelation meter, targer source meter (webradio, EBU R128 Spotify, Youtube, etc.)
Supported languages:
English, Russian, Deutsch, French
How to change language (language change supports only front page):
Go to Gear button (left bottom corner)->Ogolne->Jezyk aplikacji - and voila!
You will have a lot of visual fun with this tool.
Give a try, waiting for Your opinion!
