• English
  • Deutsch
  • Español
  • Русский
RadioBOSS box
Author Topic: Radio Logger Suggestion.  (Read 1017 times)
retired_guru
« on: February 20, 2020, 04:50:07 PM »
I just started playing with the Radio Logger program and am a registered user for both.
There is one shortfall that I have noticed that will make using the program to record long programs difficult.
The fact that it will only record 60 minute files and then start another file is a hinderance to me. I have shows that go 2+ hours and splitting the files to me is unnecessary. (I have 10 terrabyte of space online so that is not an issue.) It would be nice to be able to disable this feature or extend the timer beyond the 60 minutes or both. Is there some way I havent found yet to disable it?  Inquiring minds want to know...
Pat Morrow
CrookedRiverRadio.com
  • Administrator
    • http://www.djsoft.net
Re: Radio Logger Suggestion.
« Reply #1 on: February 22, 2020, 05:04:48 AM »
Thank you for the suggestion! Recording more than one hour will be possible in one of the future updates.
