www.housestationlive.com
- rating fields in main windows display nombers instead of stars
- tag field and backup database are welcomes
- new crossfade is awesome but missing some customisations
- on main windows track information on bottom including cover sometimes doesn't load or stop working
- embed caster have many bug, still have to use radiocaster instead (failed to update title, failed to update soundcard even after several restarts), especially on shoutcast
- still no weather
- mic and eq on the center are awesome, not only for graphic purposes
- still not possible to edit style
- most of time software doesn't warn about effects will change after restart (especially after soundcard modifications)
- excellent update, i don't planned to buy updates cause original software is expensive, but theses upgrades are fonctional and useful, hope for a stable release before my liecences expires
- special caracteres replaced with "?" in majority of cases (i uses stars or bullets ●)
- radiobosscloud login/password never works (but work fine using dj credientials)
- on track information section the very right column last information (played "hour" is invisible, cropped)
- still no ssl support shoutcast/icecast, have to use radiobosscloud to relay stream in https (google/apple requieres it nowadays)
- displaying statitics inside of the software could be great
- get statistic when using radiocaster on the same machine shouldn't be complicated
- embed server only allows 1 stream (maybe cause my router can only open 1 port)
- maybe if we can, instead of "input" adding a "sofware" in scheduler or sound card configuration, can make life easier (like on obs "capture active windows")
- also make some "targetspot" (shoutcast monetisation) section to automatically embed in playlist the right files with the right associate data (even if i heard lot of broadcasters just don't receive their check)
that's it for today !
on my website on "on air" tab i have screen capture of radioboss v6. cool software. active community and update. price are still competitive (i still don't understand how you can pay 100$ per month to radio .co to get a 320k stream, i almost not understand why shoutcast in now 10 $ monthly)
- still no weather
