RadioBOSS 6.0 [beta]
I see that this new beta version has problems in the library (at least for me) since it throws errors
Please click (in RadioBOSS) Help->Contact Support->Send bug reports, we'll see what could be wrong there.
the fact that the bug exists is that when same artists plays, there are no reports on the log, and that's why you don't have complaints from other users
Someone would have noticed it :) We also run automated tests here that should catch things like this. But they don't.
About tags, why the file name and not metadata?
to fill the blank fields in metadata?
It tries to read metdata (tags). But if a tag does not exist or artist/title fields are empty, it parses the file name.
Does "tags" play a role in "tracklist"? (there are no separation for it on options)
I think there is a confusion, there are "tags" that store metadata (e.g. ID3v2) and there are other Tags that you assign to the tracks: https://manual.djsoft.net/radioboss/en/using-tags.htm
Those are completely different. Track List does not use Tags (yet) but it reads metadata tags.
So you may write the word "sorry" but i remind you that you had 3 years since i first mention all of these... Not even 1 was accomplished.
Is there any client here that waited that time?
I'm not sure what are you waiting for. Do you still experience artist repeats in the most recent version? If so, how often does it happen?
In identifying the file types to define the color and which custom title to send to the server, is it possible to enter the search for more names to search for? This is because many format files you receive are divided into blocks e.g. "block1 block2" it might be useful to use wildcards Es: Lock*
Entering "Lock" will work, as it will include all files with this word e.g. "Lock1", "Lock2" and even "The block number one".
Tip: add Drag mode to change places between playlists already created, this helps with organization.
The Teaser here has a 0.5 second mix point that appears to be correct. Can you please also send a screenshot of a Teaser settings. The bug still does not reproduce here.
0.5 would be correct. However, that is not what happens.
It is an event, so I attach the command
Code:
TEASER=M:\Mi musica\Archivos Radio\Jingles\Teaser\Apertura|M:\Mi musica\Archivos Radio\Jingles\Teaser\Transicion|M:\Mi musica\Archivos Radio\Jingles\Teaser\Cierre|P|13||3|R|10000
Sugestão: Adicionar o modo Arrastar para mudar de lugar entre playlist já criadas.
Please write in English, this is the language used on this forum.
It's working properly with the same settings here. Does it always happen, or only sometimes? If you place another file after the teaser e.g Music, will it overlap?
Ok Thank's How to insert a live stream instead? I entered this, as you see in the photo, but I don't get the custom writing you read the stream address, why?
i am trying to use the auto intro tool to play a jingle at the start of a track that i specify, it doesn't seem to work according to the instructions
i want to play jingle amy 5 at the start of whenever midnight train to georgia plays
yes : Failed to load player settings. Please restart.
Please click the Details button to send the bug report, we'll check what could be wrong there. You can also try installing the most recent version (6.0.1.6) there's a chance the bug does not exist there already.
Hi there, is possible to make the resolution of the "artwork.png export" higher to 500px instead of 350px?
Thank you for the suggestion, a configuration option will be added to control this in one of the next updates.
It should show the custom title. Are you sure it's correctly identified as this file type - the stream is marked with the colors you specified in the settings?
Does it show any error messages in the log? How the tracks are named, do those file names really start with the text you have specified? Please note that it checks the file name - not the information in the tags.
Not only this bug,which did not show the custom title for the stream, also this : Entering "Lock" will work, as it will include all files with this word e.g. "Lock1", "Lock2" and even "The block number one". It doesn't work as you see from screnshots How to Fix it really works? I did what you asked me by submitting the error report. ( Please click (in RadioBOSS) Help->Contact Support->Send bug reports, we'll see what could be wrong there.)
what might be good is a "refresh" command or event that would refresh the scheduler window. every day i need to click and de-click the enabled check box to fresh, after various enable and disable commands have ran
hey, its not a great trouble, just a couple of clicks, but as you see from the screenshot, the group day has just disabled and stays shown in the scheduler grayed out, until i click on enabled again, but i have to do this every day a few times, maybe a refresh scheduler event
The identifier must be a single word, without any quotes commas, or anything else. In your case, I suppose it should be pantarei.
This one-word is the first thing I've done in previous versions as well, but it doesn't work. No Custom Notification arrives at the broadcast server.
In this latest version, when this error appears: "Server connection closed (output 1) Restarting ..." the track that is running has a strange behavior, a part of it is repeated three or four times and the track is cut off. transmission connection starting transmission from zero and continuing the track its normal development. This has been happening once or twice a day.
Checks your connection. Here I have not had this kind of problems. I believe if there is already a problem between your machine and your internet service
