Jingles Trunckated
tieffeitalia
Hello.. I don't know why but my jingles and files played via the cart wall are trunckated before the end, half a second before the end.. I have set all the crossfade to zero for all the filetypes... but jingles and cart wall still playing trunckated at the end.. I need help guys.
DigiART;)
Hi Dmitry,
I tried to disable the gap killer, but the result is the same... attachments.
  • trunkates_jingles.zip
In this case, it's possible that the files are corrupted, and therefore not play in full.
:confused::confused::oops: obviously I check it... I'm doing a live program with Zara Radio with no problems... I want to switch to RadioBoss because I prefer it.. the same files work well in Zara... and don't tell me now "So, you can use ZARA Radio"... I would like to fix the problem for use RadioBoss.
Problem solved reinstalling RadioBoss in a clean way. Previously I totally uninstalled it from the system it with Orbit Uninstaller.
