Bug in new RB version
Bjorn
Hi there, I've just upgraded to v6.0.6.0 and I am receiving an error when trying to load the segue editor
Please click the Details button, then Seng Bug Report, we'll see what's wrong there.
Does it happen for all tracks or only for some?
A hotfix will be released shortly to resolve this. It only happens on some computers.
Hi Dmitry, thanks for this update!
Do you have a major update planned for the segue editor? It still seems to be playing ahead of what the playbar is showing and I often get slight changes in what actually is played out to air as opposed to what I previewed and prepared in the editor.
It would also be awesome if the edited size of the waveform when gain is added in the segue or track tool would appear in the on air bar at the top. Here are some images to explain what I mean:
I've added gain to this track (as you can see) but here is what it appears as when playing "On Air"
It's still the original size :)
Thanks!
Also, the red bar at the start of a track to indicate the intro seems to disappear a few milliseconds or so after the track is played :)
Even in the sigue editor preview, the second track's audio starts before the waveform. It's out of date
I think there is still a little work left there :)
Currently not, it works as it should now (more or less). It will sound exactly the same as it will sound in the playlist - the code that processes the mixes is the same one that is actually used in the playlist. If you see any specific issue then more information is needed - what is not processed correctly (mix, fades) and in what situation.
The actual sound and the position of the playback cursor could be a bit off for a fraction of second for technical reasons. But the actual playback should be correct, how it will sound when played in the playlist.
This will be improved in the next minor update, it will take into account the Playback Level value when displaying the waveform.
Yes, it's a bug that was added when we've optimized waveform drawing. Happens only when waveform display is used, and not in other modes. The next update will be released within a week.
How much time before? Can you please send a screenshot of the Segue Editor window so we can try it here with the same settings?
Segue Editor is such an important tool for perfect streaming. Is a fallback to 6.0.5 or earlier possbile?
Can you please specify what problem do you have with the segue editor?
You can find links to the previous versions here: https://www.djsoft.net/community/threads/rollback-version-to-download-6-0-5-0.7363/post-36405
Something like this. When the zoom is at its maximum the difference is clearer.
In this image, the sound of the next track in the preview begins to play
Thanks for updating those bugs & that's great to know :)
I have also noticed a bug which only happens when you use the first fade keyframe that choses when the track starts:
I'll set the track to start like that, but when I click OK, and open it again, then the bottom track shifts to the left:
If I correct it again and click OK then it seems to work but it doesn't work the first time round :)
