Audios nao seguindo regras
Luiz Carlos
I program a time audio and then a spot block. The audio (in green) is programmed to enter before the block (in yellow), but in the programmed time it puts the hour audio (in green) and when the programmed block enters later, it ends up entering before the hour audio. How to fix it ?. Here's the screenshot
You can enable the "If there are scheduled events, enqueue" option in the event settings, this will make it put the events after the previously inserted tracks.
