Playlist generator backup
stokemusic
Would it be possible to have an option to backup all the generated playlists that have been created with the Playlist Generator?
You can backup those using any 3rd party utility that creates backups. Or you can save them into RadioBOSS's own settings folder and playlists will be backed up when you create settings backup in RadioBOSS.
Thank you for the info. Where are the playlists located? I looked in /Radioboss/Presets/PlGenPro and it's empty even though I have about 70 playlists generated. Any help would be most appreciated. Thank you.
Generated playlists and any playlists that you save manually when you press the Save button in RadioBOSS are saved top the location where you save them. In the settings folder it only keeps the playlists for the playlist tabs.
You can save your own playlists to the Settings folder to make them also being copied when you create a backup, please use a custom subfolders for that.
