InstabilSpielt
Hi, why is it possible to change the dedicated SQLite file path but not the shared one?
Shouldn't it be the other way around?
The shared means usable by multiple RadioBOSS instances (and they all need to "know" this path - so if you change it you need to change it for all instanced), while dedicated is for one instance only so its path can be configured freely.Hi, why is it possible to change the dedicated SQLite file path but not the shared one?
I would like to customize that so we can keep the database in sync across RadioBOSS instances on different servers.The shared means usable by multiple RadioBOSS instances (and they all need to "know" this path - so if you change it you need to change it for all instanced)
If you need to use it across multiple computers, you should use MySQL/MariaDB - SQLite is not a good option for your case.I would like to customize that so we can keep the database in sync across RadioBOSS instances on different servers.
It could be that all paths are fixed (I'm reluctant to check it in the tech docs ). As stated above, please consider using MySQL instead, it's way better in terms of performance and stability if you need a shared database used from multiple computers.I just noticed that it's not even possible to change the dedicated file path, if you apply the change and restart RadioBOSS the path resets.
You probably mean that: https://www.sqlite.org/howtocorrupt.html#_filesystems_with_broken_or_missing_lock_implementationsplease consider using MySQL instead, it's way better in terms of performance and stability if you need a shared database used from multiple computers.
Not only this, also performance issues. If you need shared access from multiple computers, you should use a more appropriate solution like MariaDB.I already know this problem, therefore all our VM's have access to a hard disk instead of a network drive. So it makes no difference on which drive the database is located.
Currently SQLite database location in RadioBOSS can't be changed, I'm sorry.I would just like to select on which drive the database should be stored.
I'm sorry but no. No one ever asked before about changing database location - so there's very little demand for it.Are there any plans to implement this in the future?
What problem do you need to be solved?Was searching for a solution for this problem...
Would also welcome the function, is it such a big effort to integrate?
Database size in RadioBOSS is very little, so drive performance doesn't matter much in this case. If you need overall performance improvement, you can make SSD drive the system drive, in this case, SQLite database that RadioBOSS uses will also be on that drive.Putting the database on another hard drive, in my case I would like to have it on the SSD instead of the older HDD
