patrick.de-bruyn
In the playlist you have the length of the songs.
If you use the screenreader there is a problem,
for example a song is 06:33 long the screanreder reads 6 hours, 33 minutes.
If a mix is more than an hour long for example 1:12:14 the screanreader reads correctly.
I think that if you could generally display the length of the songs with hours like here 00:06:33 that the screanreader would then read correctly
