Generate 24 Playlists with New Playlist Generation Commands System ?
Altec
Hello Dmitri,
Thank you to add the possibility to generate multiple playlists with a preset. But I can't find how to generate 24 Playlists properly.
Before the Update I was working like this :
I tried your marvellous new options, but I can't find how set the start number for each preset, exemple ALTEC-NIGHT Start Number is 0, Altermorning Is 6 to reach at the end 24 hours and 24 playlists :
I tried to modify the command like this :
"C:\Program Files (x86)\RadioBOSS\PlaylistGeneratorPro.exe" "-preset=ALTEC-NIGHT|ALTEC-MORN|ALTEC-LUNCH|ALTEC-AFTERNOON|ALTEC-AFTERWORK|ALTEC-EVENING" "-out=C:\PL\playlist_%nn.m3u8|playlist_%nn.m3u8|playlist_%nn.m3u8|playlist_%nn.m3u8|playlist_%nn.m3u8|playlist_%nn.m3u8" -n=6|6|2|4|2|4 -s=0|6|12|14|18|20 "-starttime=00:00:00" "-startday=1"
But it doesn't work, I tried that too :
Doesn't work
It could be useful to move there the "Start number" option... :
Thank You in advance
An option to set the start number for each batch will be added in one of the next updated. Currently it's only increased sequentially across all generated playlists in a command.
Is it currently possible to do what I want to do—perhaps by using a hidden argument in the command—or is that not possible yet?
There are no hidden arguments for this, the processing of -s parameter needs to be extended, and this will be done in one of the future updates. Maybe it'll be added in 7.2.2 minor update.
Thank you very much. Can you also add an argument "tomorrow" for that
Because I'm using pl generator to generate the 24 hours approximately at 11pm the day before.
Thank you in advance
Thank you Dmitri, It will be very important for me and for other users I think...
This is already possible using the existing features, you need to specify -startday=now that would mean "today" and add -starttimeshift=1440 to add 24 hours to the start time, becoming "the same time tomorrow".
I tried but i don't know if it's ok it seams it doesn't work : run "PlaylistGeneratorPro.exe" "-preset=ALTEC-NIGHT|ALTEC-MORN|ALTEC-LUNCH|ALTEC-AFTERNOON|ALTEC-AFTERWORK|ALTEC-EVENING" "-out=C:\PL\playlist_%nn.m3u8|playlist_%nn.m3u8|playlist_%nn.m3u8|playlist_%nn.m3u8|playlist_%nn.m3u8|playlist_%nn.m3u8" -n=6|6|2|4|2|3 -s=0|6|12|14|18|20 "-startday=now" "-starttime=00:00:00" "-starttimeshift=1440"
Can you please specify how it's not working? You can check the logs (menu Settings > Open Settings Folder) then open Log and playlistgenerator.log file there - it will show the effective start time it uses for playlist creation (after all options are considered).
Into the log the start day aren't the good one
