There's no such a command. I also don't recall the reason why the reboot and other commands were added - those existed from the very first days but I don't see any real usage for those
If the RadioBOSS is to be closed and the computer must continue to run so that, for example, a server continues to work.
But I have already found a method.
I do it with a batch file with the command: taskkill /im radioboss.exe
This file with run command run in the scheduler
taskkill without /f sends a WM_CLOSE message to the process, just like a click on the X in the upper right corner of the window would do.
This gives the process itself a chance to clean up and close like it normaly does
