Hourly playlist rotations (Cloud)
JulianS
Hi,
Is it possible to setup hour long playlists and have them alternate e.g.
Hour A
Hour B
Hour A
Hour B
... etc
Each would start at the top of the hour dumping anything still playing from the previous hour. Can't see how to achieve this as there doesn't seem to anywhere to set the hours played in the scheduler other than just creating specific hours (I.e) 24 scheduler entries. This in itself would be ok but not everyday is the same.
J
There's "Hours" option in the scheduled events, you can use it to start events at specific hours (you also set a minute and second). For your case you'll only need two events. You can also enable the "Clear playlist" option to make it clear the playlist window contents before a new playlist is loaded.
Sorry but I can't see the "hours" option in the event setup dialog. There is a start time edit box followed by disable event then weekdays check boxes. I am using RadioBOSS Cloud v 1.5.4.3
Yes, I'm sorry, it's not yet available in Cloud. You can try using the "Repeat" feature instead - set the start hour, and make it repeat every 120 minutes.
