Calabash Radio Member Sep 23, 2022 #1 What silence threshold means on RB and what should it be set to in the Relay
D djsoft Well-known member Staff member Sep 26, 2022 #2 Calabash Radio said: What silence threshold means on RB and what should it be set to in the Relay Click to expand... When the sound level is below the threshold, it will be considered as silence, and RadioBOSS will switch to playlist.
Calabash Radio Member Sep 28, 2022 #3 djsoft said: When the sound level is below the threshold, it will be considered as silence, and RadioBOSS will switch to playlist. Click to expand... Thank you
