Currently it's a technical limitation, stream metadata is not supported for FLAC.It does not send a stream title with flac streaming
You can use the custom encoders to add this: https://manual.djsoft.net/radioboss/en/custom-encoders.htmCould you also add FLAC without Ogg, as an further encoder?
Then Icecast would allow the metadata updates via URL and you could enjoy lossless music also with Safari.
flac.exe -s -c -8 --channels={Channels} --bps=16 --sample-rate={SampleRate} --force-raw-format --sign=signed --endian=little -
	Puede usar los codificadores personalizados para agregar esto: https://manual.djsoft.net/radioboss/en/custom-encoders.htm
El codificador se puede descargar desde aquí: https://xiph.org/flac/download.html
La línea de comando con la que puede comenzar (no probado)
[CÓDIGO]flac.exe -s -c -8 --channels={Canales} --bps=16 --sample-rate={SampleRate} --force-raw-format --sign=firmado --endian=pequeño -[/CÓDIGO]
The example command is included in the post, please see above. Please note that you also need to specify a full path to ffmpeg executable.Can You send a command for copy paste please?
That's why we use OGG container for FLAC.Not working with title & artist
So for me it works without problems (v2.4.0-kh16):Not working with title & artist
And with OGG, as a container:<title>MARTIN GARRIX & BEBE REXHA - IN THE NAME OF LOVE (THE HIM REMIX)</title>
<annotation>Content Type: audio/flac</annotation>
<title/>
<annotation>Content Type: audio/ogg</annotation>
C:\Program Files\RadioBOSS\Plugins\pcmraw.exe - -
RAW audio is sent without any headers, so the receiving part must already be told somehow what format this is (sample rate, channels, etc).I'm just a little bit confused, why the stream is just loading, even when sending RAW audio.
Is there anything special you have to consider, when using the custom encoders?ffmpeg.exe -f s16le -ac {Channels} -ar {SampleRate} -i - -f flac -
We'll check if something's wrong there. I'll update here when there's more information.RadioBOSS does not give any error and Icecast claims that the source has connected successfully, but you cannot listen to the stream with any client.
I don't recall the technical details. but probably OGG container is a requirement.RadioBOSS does not give any error and Icecast claims that the source has connected successfully, but you cannot listen to the stream with any client.
C:\Program Files (x86)\RadioBOSS\Plugins\flac.exe -s -c -8 --channels={Channels} --bps=16 --sample-rate={SampleRate} --force-raw-format --sign=signed --endian=little --ogg -
	When I apply this, I receive the title information, but the audio cannot be decoded. When I add MIME, the audio is decoded, but then the title information is not being read.I don't recall the technical details. but probably OGG container is a requirement.
Please try the following command line (change the path to your actual RadioBOSS installation path):
Code:C:\Program Files (x86)\RadioBOSS\Plugins\flac.exe -s -c -8 --channels={Channels} --bps=16 --sample-rate={SampleRate} --force-raw-format --sign=signed --endian=little --ogg -
