RadioBOSS 7.0 [beta]
I'm creating a playlist and I ran into a serious problem.
I can't find a way to give position to the advertising.
It would be great to add the "add to end of playlist" option.
add to configuration.
By adding this option we can add the events more ordered.
example:
Music List "Pop"
advertising
Music List "Rock"
advertising
Info List "mountains"
A strange error occurs in the browser, when I restart RadioBoss and click to update the address in the bar, the browser adds the https protocol once again, in this case it does not open the address. It should identify that it is already inserted but it doesn't, it adds it again. I'm using Windows 10 64 bits and
RadioBoss 7.0.0.9
yes there is.
Weather (tomorrow) update error: HTTP/1.1 401 Unauthorized
This means there's no weather data for tomorrow, so that's why weather variables for tomorrow's weather will not work. Please try using the AccuWeather option without specifying an API key, it should work.
So it's not possible to have the option to choose the storage location for the .rbdata folder ?!
.rbdata files are either stored in the same folder where music files are (the File option) or inside the .rbdata folder if you choose "File (subfolder)" option.
Where can I check if the end of dtmf tones is inactive?
It's in Settings, DTMF section.
Will be added in the next update.
RadioBoss 7.0.0.9
Thank you, looks like a bug.
RadioBOSS 7.0.1.0 beta (1/29/2024)
Changes
  • Auto Intro: added intro tracks filters
  • Auto Intro: added rule check order option
  • Music Library: redesigned tag editor window; track artwork can be edited
  • Added HTTPS streaming support for integrated server
  • Added fade out option when the relay is turned off
  • Time Zone option changed to Clock Adjust option allowing more gradual control
  • Fixed web browser incorrect https:// addition
  • Fixed: occasional short UI freeze on broadcasting encoder start/stop
  • Minor improvements and bugs fixed
x86 https://dl.djsoft.net/beta/radioboss_setup_7.0.1.0.exe (1/29/2024, 34MB)
x64 https://dl.djsoft.net/beta/radioboss_setup_7.0.1.0_x64.exe (1/29/2024, 38MB)
Hello.
After installing the latest update 7.0.1.0x64, i get the following error. It refers to drive N: which I do not have on my computer.
Kind regards.
When I click Auto Intro > New on Filters RB crashes. When I do it in the already existing Auto Intro everything is fine.
I get this message:
Access violation at address 00000000015792B0 in module 'radioboss.exe'. Read of address 0000000000000088.
Program will be restarted because of fatal error.
This window keeps popping up until I restart RB. Then after some time, it pops up again repeatedly. RB 7.0.1.0 x64
Changes
Error in this new version
Bug report sent
Hello, I see a gap before the start of a teaser. Good evening
Can you please provide some details - is there a silence or freeze when starting a Teaser? Please post a screenshot of the teaser configuration window.
Now I discovered - when I mouse over an Event in the Scheduler, this pops up and keeps appearing.
A hotfix was released that should address this. Can you please send a screenshot of RadioBOSS main window so we can double check it with your column configuration in the event window?
Did you mean this? This is a test RB, so I don't have many events.
between the broadcast of the last title and the start of the teaser I observe a gap
Unfortunately, the issue was not resolved with the hotfix. Now the error is slightly different. When I hover over 'Event' without clicking, the error doesn't occur, but when I hover over 'Group Name' the error reappears.
There is also a video of this strange error. I had to zip it because the attachment doesn't support video files.
