Can you please provide more details on it?noticed the event to pull in a playlist fire when events are turned off. Had to disable it totally.
This is not right, it's vulnerable to SQL injection attacks and can cause all sorts of other problems. I advice to search google about prepared SQL statements, or escaping values before inserting them into query.SET `lyrics` = '$lyrics'
We don't plan adding it. FTP works separately. You can monitor the folder periodically for changes.There still is no proper notification after FTP is sent to enable firing of notification.
You can transmit artwork in HTTP request, instead of using FTP - there's %artwork variable that holds the artwork (base64-encoded), so you can get all nowplaying info from one request, without using FTP at all.Yes, but it creates an unrealistic lag while the timer runs to update it which is silly. This is particularly unhelpful as the lyrics need coming in at same time as the song update and the reading of lyrics. I have asked you for this many times as the carrier notifications cannot predict the ftp has finished executing.
I don't know what Google has to do about it. No one else has any problems with requests with parameters. This is a common feature and it's surely working. XML exists for cases when metadata needs to be exported into a file.Yes but it gets blocked by google servers on five sites I tried its why you made XML
I don't understand this resource preservation, this is not a problem nowadays. As I told you before, you should consider changing your web hosting. It's way too restrictive. It doesn't allow you to do basic things. We won't be adapting RadioBOSS to work with such limited web sites, that I can tell you for sure.Well, it runs better through XML of FTP as creates no overhead on server which you are already aware of. The only processing it from disk twice one for image once for XML creates extra overhead on internet server.
