About the "last played" history
xzsaimon16
About the "last played" history is not shown in the last played column of the "search".
It is only shown when it is collapsed and not when it is expanded
You need to hover the Last Played cell and in the tooltip it will show the last 5 runs.
Yes, but I mean that it is shown in the same way (by positioning the cursor) as in the PL, in "search".. In order to see quickly by just positioning the cursor over the songs in "last played" of "search" .
Also for a future update, show the hours and minutes.
(15min ago)
(12 hours ago)
I'm not sure I understand this.
(15min ago)
(12 hours ago)
Noted for the future versions.
I mean that the "search" history is not shown like in the PL
I see, there's actually a bug in there - will be fixed in the next update. For now, to make it show the tooltip, make the Last Played column more narrow, so that time doesn't fit there (make it show ... at the end).
I also just saw this bug. In normal width mode: No tooltip is displayed (Capture #1).
The tooltip is only displayed when hovering over the last visible line of the "Last time played" cell (capture #2).
In narrower column width mode: I actually see all the tooltips.
This will therefore be corrected. Thanks.
Can you ensure that the width of the tooltip will be wide enough to display the information clearly? That is, one line per date. Currently, a date corresponds to approximately 3 lines (Capture #3). The information is very condensed and lacks clarity.
