Track list event
How i make a Track list event
I need the track list will come in at a certain time
Please use the Wizard button, then select "Play one track from a playlist or folder".
The problem is that I create such a schedule and it goes into playback, then another broadcast schedule comes in and then it deletes the entire playlist
And I didn't check in the "delete playlist" setting
why is it happening?
The event could have an option "Replace scheduled tracks" which will delete any tracks that were added by the other scheduled events. If you want some tracks not be affected by this, you can probably set "Insert as: regular playlist tracks" option.
Please see this user manual page about scheduled events options: https://manual.djsoft.net/radioboss/en/eventoptions2.htm
