Clear Playist or Remove Previous Schedule from the playlist
mysoulradio
Question on the latest update can you tell me how to Clear Playist or Remove Previous Schedule from the playlist. I dont see this feature.
Thank You
This is controlled in the Insert Position box - to clear playlist, select the Replace Playlist option, to remove the previously scheduled tracks, select the Replace Scheduled option.
Is there a way to select "Que after the playing track" in the insert position box and to have any songs from the previous playlist (apart from the playing track) be cleared? I'm struggling to do this. At the moment once I select "Que after the playing track", when the new playlist loads, the old songs are still there from the previous playlist.
With the event's options you can either clear the playlist, clear scheduled tracks, or leave it and insert new event to the playlist window. Deleting the playing track is not a problem - it will continue playing. So in your case it seems to select the "Replace playlist" option.
I just tried that. And it worked! Thank you :)
