How to " Auto Generate 24 Hour Playlists" with Voice Track Inserts
RebootFM.com
I'd like to perpetually auto generate playlists as I'll be away for the month, and insert voice tracks to execute around the clock, every 15 minutes, is this possible??
Hi, can you tell me exactly where and how to put "VoiceTrack" in the Playlist Generator Pro list?
I need something like this (see photo)
It will work this way, if you want a voice track to be inserted between Top11 and Old categories. The Voicetracks category need to contain the voice tracks.
Funzionerà in questo modo, se vuoi che una traccia vocale venga inserita tra le categorie Top11 e Old. La categoria Voicetracks deve contenere le tracce vocali.
Hi, regarding the VoiceTrack feature, can you explain exactly how it works?
I have 10 audio tracks in a folder, with different durations, from a minimum of 3 seconds to a maximum of 14 seconds.
This folder is present in the file types, with the "consider a vocal track" checkbox and inserted into the rotation by PLG Pro.
Let's say I always insert a file (classified as a vocal track) randomly between two songs:
1) If there is only the intro, what happens?
2) If there is only the outro, what happens?
3) The song on air has no outro, but the next one has an intro, what happens?
4) The song on air has an outro, but the next one does not have an intro, what happens?
5) The song on air has an outro and the next song has an intro, but the intro is shorter than the selected vocal track file. What happens?
6) Opposite case: the song on air has an outro and the next song has an intro, but the intro is longer than the selected vocal track file. What happens?
7) When there are scheduled events that are added to the playlist, at the end of the song that is playing, how does the vocal track file behave that is moved down and ends up attached to another song? Does it just play the song or does it behave as an AutoIntro?
8) What exactly does the advanced vocal track option, which is "false" by default, mean? If I set it to "true", what happens?
Thanks in advance and sorry for the many questions
In the current stable version, if the intro or outro is not set, it's considered as zero. In the beta version (RadioBOSS 7.1) a new feature was added: default intro (outro) value which you can set and it will be applied for music tracks w/o intro/outro set.
If a voice track doesn't fit in intro+outro part, it will still play, in the part without the music a voice track bed will play (you can set it in settings).
Voice track is aligned so that it ends when the intro ends.
It will play with the other track.
Can you please specify where this option is and what is the exact name of it?
Okay, good :)
I attach a photo.
So, regarding my questions; can you provide more information about that button? Thanks
I attach a photo.
If this is enabled, it does what it says - ignored the Outro point and simply aligns the voice track to end at the track's intro. It doesn't care about anything else (e.g. when the voice track start playing on the previous track).
