Help me with mic setting
cspat
Hello everyone
I am new on this forum and I am trying to use radioboss with group of kids in club,
I setup radioboss and also my soundcard ( m audio m-track quad with 4 input and 4 output ), everything works fine ..
Just in the setting of mic button, i chose ( ASIO driver ) and the name of my sound card ( m audio m-track quad ) which apear there, and the 1st input ( my first microphone ) ( right and left )...
Then on the main setting window i set the other input, ( input 1 = first mic ) , ) input 2 = 2nd mic ), ( input 3 = 3rd mic )...
The problem is that when i start working and hit th mic button..its work only with 1 microphone as its selectd on the setting on button, and others mic will not work..
Is there any setting i missed ?!!!
Help me please, and thanks in advence
I want to enable the 3 microphone when i hit the mic button to use it in interview
When you press the MIC button, it will only activate the input that's selected for "MIC button". Other inputs are activated separately: https://manual.djsoft.net/radioboss/en/working_with_linear_input.htm
If you want the three microphones activated by pressing the MIC button you should either use a mixer board, or use software mixing solution. Usually multi-input sound cards have their own control panel where you can configure the mixing.
Windows only lets you use 1 input at a time you will have to add some hardware a mixer maybe a A2D i would recomend Focusrite
In RadioBOSS you can use multiple inputs at the same time, e.g. Mic and any additional Inputs 1/2/3.
Thanks for replay .. i try to find a soulition to use all the 4mics by click on ( mic button ) , m audio has no software or control panel to allow that, and if i insert ( line 1 ) in playlist its work but with no background low music
You can use 3rd party virtual mixing software e.g. https://vb-audio.com/Voicemeeter/index.htm
In one of the future updates, RadioBOSS will offer its own virtual mixer.
This is quite interesting. So, if I'm correct, could you combine a mic and line input by turning on the mic, and then adding the line input to the playlist? If this is the case, can you specify a time of 0 to specify that you want the line input on indefinitely? If so, with the mixer and some software that would give you virtual inputs you should theoretically be able to being in a cohost, and use pre-listen (activated with alt+r) to hear them while a track is playing. I haven't tried all of this yet because I'm not near a setup that would provide the virtualization at the moment, so thought I'd ask here.
You don't need to use line inputs for this. Microphones are mixed to some virtual device, and you configure the MIC button in RadioBOSS to use this virtual device - so that when you press it, all mics are activated.
