Scheduled Events into "Playlist Generator Pro"
Davide72
Good evening;
a piece of information, is there a way to mark as "scheduled songs" directly inside "Playlist Generator Pro" some objects that I would like to be associated without any interruptions between the first and the second, due, for example, to the start of another scheduled event controlled by the event scheduler? For example, in the image, I would like "Italiane Nuove" to always go after "Jingle Hit Italia Playlist", but sometimes it happens that a scheduled track is inserted between the two.
This is not possible, I'm sorry. You can pack the entire playlist into a container to make it play as a one item. But marking of some sections of the playlist is not supported.
Good evening;
Schedule (directly from the scheduler at the minute/hour you prefer) a tracklist for the "Jingle Hit Italia Playlist" as the opening Jingle and then another tracklist "Italiane Nuove".
And set "load as scheduled tracks" so that they are always played.
Thank you but I wanted to plan it directly from "Playlist Generator pro" in order to always follow the predetermined sequence.
You can try to do something similar.
And check that there is not an event starting when you know that more or less this musical sequence should go on air
I forgot: select in the "general" tab that it must take into account 2 tracks
This will not really work. With a configuration like this, it will choose the two tracks from the first library, and will continue selecting like this until it uses all music from the first library, only then it will start selecting from the second one.
If you need a structure music-jingle-music etc then you should create two separate categories and add them to the rotation.
I think the solution is to add a "voice over" to all the tracks of the playlist with "position end" so that the jingle always starts at the beginning of each single track without overlapping it. But perhaps the same result can be achieved by adding "tags" to the files.
For this, in the Auto Intro rule set - Position: End at, and value: 0, this will make the intros play before the track.
Similar result can be achieved in the Playlist Generator, precede music categories with intro categories and set crossafade settings to prevent intros overlapping music (create a file type, set its mix point to zero).
Yes, perfect. I set "Auto Intro" with "tags" with "end at 0" values and it works great. Thank you :)
