TBN Radio
It can be the mix point (Trigger mix at option) so you should process that also.
I am a bit confused about this option under the music library. What does it do? Is it the same as the crossfade option? I have already enabled Crossfade for the files. Should Mix Point be left at the default settings or adjusted? Does it affect the crossfade as well? Under Crossfade, I have enabled Mix Point, Trigger Mix at, Fade Out, and Start Fading Out on Mix for each file.
However, I was previously advised to turn off the processing of Trigger Mix Point and Gap Killer, as they do not calculate the exact track start and end time.
To make RadioBOSS calculate the Start Time precisely, the Trigger Mix At and the Gap Killer features can be turned off or tracks must be processed in advance.
RadioBOSS calculates an estimated "Start Time" for each track in the playlist, but this time can be off by several seconds due to features that affect the track's playback time. This also affects the calculation of the total playlist duration.
Features that affect duration/start time:
1. Gap Killer removes silence at the beginning and end of the track. By default, this is evaluated when the track is started. Until then, RadioBOSS doesn't "know" how much silence the track contains, and therefore, the exact track duration is unknown.
2. Trigger Mix At in the Crossfade settings...
- djsoft
- Forum: How To Guides
