Playlistgen Error with sheduled Playlist Generation
Jörg B
I already had this issue with the beta version, but the error has not been fixed. My server is currently still running version 7.0.8.0, because even the final version 7.1.1.4 causes an error when generating certain playlists via the scheduler. However, this issue really only occurs under 7.1, not under 7.0.8.0.
One example is my regional news playlist. RadioBOSS is supposed to generate a playlist at specific times containing the following elements:
  1. Opener
  2. First news
  3. Transition sound
  4. Second news
  5. Transition sound
  6. Third news
  7. Closer
A music bed runs underneath it, and the news segments are marked as voicetracks. I created a preset for this in the Playlist Generator. Under both 7.0.8.0 using the scheduler and 7.1.1.4 when manually clicking “Generate” in the Playlist Generator, the playlist is generated correctly, and I can then load or play it as a playlist.
However, if I try to start the event with the preset via the scheduler under 7.1.1.4, I get the following error:
"Playlistgen Error Preset =Regionews"
The same applies to my event announcements, which are planned in a similar way. As mentioned, everything still works without any problems under 7.0.8.0.
Can you please specify the exact error message?
To better diagnose this, please send us playlistgenerator.log file from the Log folder (Settings->Open Settings Folder).
Please also specify how do you create the playlists via the scheduler, do you use the generate command or it's executed via the run command? (you can post a screenshot of the event).
I can't find any error in the logfile of the playlist generator, except for the fact that no file is found in the category "Speaker". However, that's simply because there is only a file in this category if the news is actually spoken by a human. If it is generated via TTS, like in this case, no speaker name appears as a file in the folder. Moreover, the playlist can be created without any issues directly via the playlist generator; the "PlaylistGen Error" only appears when executing the event. Also, everything works fine — both in my test environment with version 7.1.1.4 and in my main environment with version 7.0.8.0. - - -
Here is the Content of the Logfile created a few minutes ago.
[2025-04-24 14:37:46] Preset: Regionews
[2025-04-24 14:37:46] ------------------------------------
[2025-04-24 14:37:46] Generation started.
[2025-04-24 14:37:46] Loading category "Regionews Trigger HP"
[2025-04-24 14:37:46] Category "Regionews Trigger HP": loaded 1 tracks [time spent: 00:00]
[2025-04-24 14:37:46] Tracks in category: 1 [time spent: 00:00]
[2025-04-24 14:37:46] Loading category "Opener Lokalnachrichten"
[2025-04-24 14:37:46] Category "Opener Lokalnachrichten": loaded 1 tracks [time spent: 00:00]
[2025-04-24 14:37:46] Loading category "Sprecher"
[2025-04-24 14:37:46] Category "Sprecher": loaded 0 tracks [time spent: 00:00]
[2025-04-24 14:37:46] Tracks in category: 0 [time spent: 00:00]
[2025-04-24 14:37:46] Loading category "Stinger"
[2025-04-24 14:37:46] Category "Stinger": loaded 1 tracks [time spent: 00:00]
[2025-04-24 14:37:46] Loading category "Closer"
[2025-04-24 14:37:46] Category "Closer": loaded 1 tracks [time spent: 00:00]
[2025-04-24 14:37:46] Loading category "Meldungen"
[2025-04-24 14:37:46] Category "Meldungen": loaded 3 tracks [time spent: 00:00]
[2025-04-24 14:37:46] Tracks in category: 3 [time spent: 00:00]
[2025-04-24 14:37:46] Creating playlist...
[2025-04-24 14:37:46] Selecting from category: Regionews Trigger HP
[2025-04-24 14:37:46] Selected duration: 00:00.0
[2025-04-24 14:37:46] Selecting from category: Opener Lokalnachrichten
[2025-04-24 14:37:46] Selected duration: 00:05.4
[2025-04-24 14:37:46] Selecting from category: Sprecher
[2025-04-24 14:37:46] No appropriate tracks in category "Sprecher".
[2025-04-24 14:37:46] Selecting from category: Stinger
[2025-04-24 14:37:46] Selecting from category: Meldungen
[2025-04-24 14:37:46] Selected duration: 00:23.7
[2025-04-24 14:37:46] Selected duration: 00:32.1
[2025-04-24 14:37:46] Selected duration: 00:20.4
[2025-04-24 14:37:46] Selecting from category: Closer
[2025-04-24 14:37:46] Selected duration: 00:18.3
[2025-04-24 14:37:46] Total time spent: 00:00
[2025-04-24 14:37:46] Completed. Playlist duration: 01:40
[2025-04-24 14:37:46] Saved file: E:\audio\#automatische Beitragserstellung\Regionews\Playlist\Regionews.m3u8
[2025-04-24 14:37:46] Done.
To clarify, does it work fine now, or it's still failing when created via the scheduler?
Since the logs show that the playlist was generated (and the fact that manual generation has no problem as most have reported) - the problem seems to not be playlist generation per se but playlist generation and THEN loading that playlist into the live playlist display for broadcast. I have been experiencing the very same problem. I had to downgrade to version 7.0.5 for this problem to vanish. The problem pertains to launching playlist generation via events and having that generated playlist load. Playlist Events I created in version 7.0.8 cannot load automatically in that version, and now in 7.1 too.
Sorry, a mistake must have happened. I meant: 1. Productive system on 7.0.8.0 is working, and the sandbox on 7.1.1.4 is causing the playlistgen error.
From what you describe, looks like the problem is the generate command. Now it's recommended to use two events - one to create the playlist and save it to a file (this can be configured from the wizard) and then another event to play the playlist. generate command's downside is that creating a playlist takes time, so it's unpredictable when it will actually launch.
The generate command will be fixed of course but it's still not recommended to be used.
"My playlists are always generated separately. I do not have any events that generate a playlist and then immediately start playback. Some of the playlists are not even played at all, they are only saved. In any case, there is always at least a 15-minute gap between creating and playing the saved playlist. The events that play playlists are ALWAYS separate from the ones that generate them."
In this case there's no bug, I did a quick test using RB 7.1.1.4 and a command
Code:
run PlaylistGeneratorPro.exe "-preset=1" "-out=C:\Test\1.m3u8"
- had successfully created and saved the playlist.
Can you please share your entire command here, maybe the problems is there.
The Command is: run PlaylistGeneratorPro.exe "-preset=Regionews" "-out=E:\audio\#automatische Beitragserstellung\Regionews\Playlist\Regionews.m3u8"
It works on 7.0.8.0 but the Error ocures on 7.1. The same with: run PlaylistGeneratorPro.exe "-preset=Erstellung Veranstaltungstipps" "-out=E:\audio\#automatische Beitragserstellung\Beiträge\Veranstaltungstipps\Playlist\Veranstaltung.m3u8 - But for example: run PlaylistGeneratorPro.exe "-preset=Newscontainer18uhr" "-out=E:\audio\Containerplaylists\Newscontainer\18Uhr\Newscontainer.m3u8" works correctly on both systems 7.0.8.0 and 7.1.1.4.
To further investigate this error, I conducted the following test. In my test environment with version 7.1.1.4, I replaced the playlistgeneratorpro.exe with the one from my other system running version 7.0.8.0, meaning the older version. Then I triggered the playlist generation again, and it worked absolutely without any issues. After switching back to the new version of PlaylistGeneratorPro that belongs to version 7.1.1.4, the error occurred again. I believe it's a problem with the command being passed from the scheduler to PlaylistGeneratorPro, because when creating the playlist manually, there are no errors in the log of PlaylistGeneratorPro. Maybe this helps narrow down the cause of the issue.
Interesting. I tried this but didn't work for me. ☹️
Can manually generate playlists but still can't as scheduled events in the new version.
but in my case, the problem apears also, when i creat a playlist in sheduler to save it as a m3u8-File.
To clarify, there's no actual error message anywhere, it just doesn't create the playlist, right?
We'll see if there's some sort of a bug but for now this problem doesn't reproduce here.
OK, at the moment there is an interrems Solution. I installed 7.1.1.4 now but i have replaced the Playlistcreatorprpro.exe with the one from 7.0.8.0 That works well for the moment. But it is very likely, that there is a problem in handling between the new version of Playlistgeneratorpro and the Sheduler.
This is a temporary solution, as this also removes any of the new features that were added in the newer Playlist Generator.
In my case the log *file* shows the playlist was generated as a scheduled event. When I open the log file I see the songs. However the broadcast log displays a playlist generator error and then refuses to load that playlist automatically as it's supposed to. When I revert back to version 7.0.5 the problem disappears.
You use the run command (not generate command), right? (if you're not sure please check the scheduled event's action. If possible, please send us a preset from playlist generator (menu Settings, Open Settings Folder, Presets folder, PlGenPro folder contains presets).
For my scheduled events I use the generate playlist command then select replace playlist or cue after playing item.
Here are 2 presets https://we.tl/t-AsNsnphHEI
