Incorrect FadeOut on TrackTool
matteolop
Hi, as you can see from the video from second 30, the fade out behaves strangely, if the playback is moved back before it ends to the end point.
Can you understand and can it be solved?
Preamble:
The video shows the different sound level states when using the "Fade Out" mix point in the Track Tool.​
This is the "Fade Out" effect, which continues until you stop playback.​
This fade-out effect actually continues when you click on a previous point in the waveform.​
And the opposite effect occurs, i.e., an instant increase in the sound level, when you return to this mix point.​
I get the same result.​
It seems logical to me.​
However, I understand that this can be annoying because the "Fade Out" sound level effect continues to occur even if you select a point earlier than this mix point.
You must select another earlier point a second time during current playback for the "Fade Out" effect to stop.
In any case, you must stop playback to also stop the "Fade Out" effect.
We'll see if the support team can improve this.
Another note:
I'm taking advantage of this thread to report a time shift of the "Mix" mix point when it is positioned on the track's waveform.
This point must be assigned 3 to 4 milliseconds earlier for the mix to be correct when the track is played in the playlist.
Example attached.
If I had set the mix point to the "kick" of the waveform, the next track would have started 3 milliseconds later after the "kick."
And the mix wouldn't have been good with the next track.
This applies to all tracks.
Once the Fade Out point is reached, there's no going back, the track will fade out. This is not going to be changed any time soon.
3 milliseconds (ms) is a very tiny interval. 3/1000 of a second. Are you sure you're able to hear it? Track Tool's precision is 10ms.
Indeed, 3 thousandths of a second (ms) isn't noticeable at all.
I was wrong: it's hundredths of a second. So, 3 hundredths of a second (or 30 milliseonds - 30 ms) , for example.
And this discrepancy is audible in the playlist.
