I am having a similar issue that throws the same error number PIGen Error 1
Im my case I can generate the playlist without issue, but when I try to create an event to generate it I get the error. What makes this even more strange is if I change the songs it can generate the playlist as an event.
For example I create a Playlist of songs and call it "A". Test the list ... it works fine. I create an event and it fails
BUT
If I change the songs that are in list "A" the event generates without issue.
I'm at a loss to where to start to even try to track that one down.
Additional Note: Once I had this working, I tried again to change the playlist back to the original songs I had selected. Again it failed.
It can't be a problem with finding the tracks as it can find them ok if I generate it manually.
It can't be a problem with finding the playlist when it can find the playlist with different songs in the selection.
We have been discussing this issue for some weeks now in these forums but the RB team says they are unable to reproduce the problem on their end so they don't have an answer yet but are looking into it. Hope they figure it out soon.
In the meantime, to downgrade to the older version again, is it simply a matter of running the exe file for 7.0.8 again, or is that likely to break changes made since the "upgrade" to the current version?
Yes. In my case I had the install file for version 7.0.5 saved somewhere so I reinstalled that. I did however back up my settings and data base from the new version and restored it in 7.0.5. For now the PlGen issue is solved and it's working fine. Though it sucks because I would prefer to be using the latest version.
