Jörg B
Hello, there are many problems and discrepancies when creating playlists using PlaylistGenerator Pro and the Scheduler. It is now strongly recommended to only use the command generate PresetName in the Scheduler going forward. This works reliably as long as the playlists generated are played immediately and not saved as m3u8 files.
For example, if I use the assistant and select “Generate playlist” and tick the checkbox “Do not play, but save playlist,” the assistant still creates the old command using run playlistgeneratorpro.exe, like this:
run PlaylistGeneratorPro.exe "-preset=Zusammenstellung Lokalnachrichten" "-out=E:\audio\#automatische Beitragserstellung\Regionews\Playlist\Regionews.m3u8"
This command, however, causes a PlaylistGen Error 1.
If I then manually change the command to:
generate "Zusammenstellung Lokalnachrichten" "-out=E:\audio\#automatische Beitragserstellung\Regionews\Playlist\Regionews.m3u8"
it results in PlaylistGen Error 3: “cannot find Preset …” – probably because everything following generate is interpreted as the preset name.
But the old command with run playlistgeneratorpro.exe is no longer supposed to be used and also causes PlaylistGen Error 1. What can I do? I want to generate playlists that are then loaded later, for example to play local news.
