Ads Scheduler : TrackTool editing directly from Tracklist in Ad Properties
Altec
Hi Dmitri,
Firstly, thank you to listen our requests every time it's very appreciable, and we're all proud to contribute for the RadioBoss development.
It could be very useful to have a shortcut to open ads tracks in the TrackTool directly from the context menu when you do a right click on the track
Best
Altec
I'd like to take this opportunity to ask if it's possible to add a prelisten column.
This would allow us to verify the content of the spot (dates of a commercial, sector of activity, etc.)
Noted for the future updates, thank you.
What if the ad has multiple items available, which one should it play? Also, prelisten option is available in the Ad Properties window when you edit it.
Sorry, I hadn't considered the possibility of including multiple items in an ad.
Perhaps a tree view would display each item with a "Play" icon (see attachment)? I have doubts about the possibility of implementing this configuration…
My initial suggestion was to be able to listen to an item without double-clicking the ad and right-clicking the item. Then click to listen. It's a bit of a long process.
Converting this to a tree is way too much work that I doubt will pay off :)
It can prelisten first track if there are multiple tracks I think.
Yes, that would be an interesting implementation. All my listings have only one item. For other users who put multiple items in an ad, they will be able to listen to the first item in the ad quickly get the idea.
Hello, I made a request for the adscheduler a while ago to allow me to insert or schedule a comment so I know what time the commercial break falls on. Could this be taken into account for the next software update?
This will be added in one of the future updates.
The comments will be inside the playlist, so are not be visible until the playlist is loaded. You can see the time when the playlist is supposed to play from its file name - it has day of the week and time there.
That's the idea, that when you generate the batch with the commercials that run during that time slot, a comment will appear at the top first stating what time that batch belongs to.
something like this:
A ideia é que, quando você gera o lote com os comerciais que serão exibidos naquele horário, um comentário aparecerá primeiro no topo informando a que horário aquele lote pertence.
algo assim:
ISTO PARECERIA MAIS PROFISSIONAL...GOSTEI DA IDEIA,
THIS WOULD LOOK MORE PROFESSIONAL....I LIKED THE IDEA,
