PGP Global repetition rules
I want to add the same repeat rules to different presets, but I can't find that option. How do I do that?
If you refer to the repeat protection rules defined in the category on the No Repeat tab - those rules can be saved to a file and then loaded in any different category.
Repeat protection rules defined in the main window can't be exported/imported (but there are not too many setting so they can be replicated manually easily). Or, if you want it for a new preset, then maybe just same the preset under a different name (so it'll keep all the settings) and then configure it as needed.
Well, to speed up the work.
This is how I did it.
