If you refer to the repeat protection rules defined in the category on the No Repeat tab - those rules can be saved to a file and then loaded in any different category.I want to add the same repeat rules to different presets, but I can't find that option. How do I do that?
Well, to speed up the work.If you refer to the repeat protection rules defined in the category on the No Repeat tab - those rules can be saved to a file and then loaded in any different category.
This is how I did it.Repeat protection rules defined in the main window can't be exported/imported (but there are not too many setting so they can be replicated manually easily). Or, if you want it for a new preset, then maybe just same the preset under a different name (so it'll keep all the settings) and then configure it as needed.
Is it required to create new presets for the playlist generator? Typical use case is that those presets are created initially, then once in a while, new presets are created. But not too often. I'm not sure that new preset creation has to be optimized.Well, to speed up the work.
The playlist generator does not repeat tracks, if you have configured it properly. In your case it seems that the playlists are created, but not played yet. So when creating the next playlist, it looks at the tracks that are in the playlist window, waiting to be played. It checks only tracks after the playing track. And how many tracks - depends on the settings in the playlist generator: Settings tab, "Repeat protection considering tracks in the playlist" (must be enabled) and click the "..." button to set up how this works.I think we need to create a more intuitive system, one that allows the system to think of better options so as not to repeat a clue.
Is there a limit to what you can create or is it unlimited?Is it required to create new presets for the playlist generator? Typical use case is that those presets are created initially, then once in a while, new presets are created. But not too often. I'm not sure that new preset creation has to be optimized.
The lists were played and I took the time to do the tests.The playlist generator does not repeat tracks, if you have configured it properly. In your case it seems that the playlists are created, but not played yet. So when creating the next playlist, it looks at the tracks that are in the playlist window, waiting to be played. It checks only tracks after the playing track. And how many tracks - depends on the settings in the playlist generator: Settings tab, "Repeat protection considering tracks in the playlist" (must be enabled) and click the "..." button to set up how this works.
You can have as many presets as needed.Is there a limit to what you can create or is it unlimited?
It depends on how they were created. Did you create them all first then they were played? If so, it depends a lot how they were created. If one by one, then "Check tracks in the playlist" option matters a lot. If they all created in one go, then there will be no repeats as internally they share the same repeat protection buffer.The lists were played and I took the time to do the tests.
