Major GUI Scaling/Compatibility Issues with 4K on Windows Server 2022
JeanXeb
Hello Dmitry,
I'm still experiencing major GUI scaling issues with RadioBOSS 7.1.5.1 in a 4K resolution. My setup is Windows Server 2022 running as a guest on Hyper-V.
The interface is tiny and blurry, making it unusable. I've tried all the usual DPI scaling tricks without any success.
Is there any fix or update planned for this? It's a critical problem for anyone using a modern high-resolution monitor with a virtualized setup.
Thanks for any info.
Best regards,
This is an issue with the UI library that RadioBOSS uses, it doesn't handle the case when the program is accessed on a remote server using screens with different DPI. We're aware of this problem and looking for a solution. I'm sorry for the inconvenience that it causes, but for now there's nothing that we have to offer about it.
Thank you so much for your kind response and for acknowledging the issue .
I truly appreciate your transparency and the fact that you're actively looking into a solution.
Best regards
Hello Dmitry,
Best regards,
I Have the same problem...
Thanks to take the problem into account we're really sorry you don't find a solution :'(
Best
One possible solution to try in RadioBOSS: right-click RadioBOSS shortcut, Properties, Compatibility, Change High DPI settings, High DPI scaling override - set to "System (Enhanced)". This will disable UI zooming that RadioBOSS does.
High DPI support is good enough, but for some cases (like remote access from different DPI screens) it does not. You can try the solution above until this problem is solved.
Unfortunately, none of the proposed resolutions work in my case. I’ve tried the DPI scaling override and other compatibility settings, but the interface remains tiny and blurry. The issue is still present and makes RadioBOSS unusable on my 4K setup with Windows Server 2022 in Hyper‑V.
Strange, something should have worked, as it seems to be scaling issue based on different DPI settings on host and client computers.
What happens if you enable UI scaling from Settings > View > Style, does it make all secondary windows (all windows except the main window) look better?
The problem occurs everywhere regardless of the Windows dpi settings and RadioBoss styles.
The screenshots attached to this message are real. You need a magnifying glass to read them in the software.
The problem is either very small or very big.
I think you should be able to fix this by adjusting the font sizes/UI scale in Settings > View > Style.
Unfortunately, that doesn't solve the problem at all. I tried basic fonts and basic styles, but it doesn't change anything.
For secondary windows, try playing with font sizes and zoom setting. For the main window, font sizes. The issue should be addressed in RadioBOSS 7.2.
