Fading long songs
Fading long songs. I haven't checked, to be honest. Do you know if there's a feature to shorten long songs? If I have songs in my playlist that are over 5 minutes long, is there a way for the control panel to fade them out to the next song?
I've always done this individually, but it's very inconvenient. The same goes for the filter that eliminates songs longer than 5 minutes. I was wondering if there's a way to tell rb to fade out songs longer than 5 minutes, but not eliminate them.
You can use the Track Tool to set Start/End points where needed to trim the song duration. There's no way to automate this based on song's duration (it can only automatically trim silence). Doing it manually will ensure the song ends at an appropriate point and will sound better.
Hi. For example, if I have more than 300 songs that are longer than 5 minutes, what do I do? Do I edit them one by one? Nah.
Please see my reply above, doing it manually will provide better results.
Ok thanks I know how to use the intro outro fine functions, etc. very well. The answer to my question was simple: No, Radioboss is not able to do it automatically.
RadioBOSS is not able. If you have lots of songs and need it to be automated, and you use the default SQLite option to store the additional information, you can create a script (or ask GPT to do it) to modify the database - e.g. set Mix and Fade Out options for tracks where duration is longer than certain value. All this information is in the "tracks2" table.
